*** Same as my Therion 75C Blue theme but jazzed up with rainbows! Puuuurdy. ***
US version: Date format m.d.yy and spelling e.g. atomizer
UK/AU version: Date format d.m.yy and spelling e.g. atomiser
Backgrounds:
Diagonal
Vertical
Features / how to use:
etc. etc... Please note that you won't actually see 'DNA' on the screen, only relevant text.
-Selecting the coil material on the Main Screen takes you directly to atomiser settings. Note that coil material is not displayed if you are in wattage mode.
-Board temperature and battery voltage are displayed at the bottom of the Main Screen.
3 = Screen turns off
2 = Very dim
1 = Dim
-Indicator light:
Fade in/out red = charging
Green = charge complete
Blue/purple = firing
Enjoy!
What's New in Version 1.0.1 See changelog
Removed Preheat Settings screen and added the options to Atomiser Settings screen.
Battery gauge adjustments.
With version 1.0.1:- Download
