Hi all,
I own a new box with dna80c and tried 4 different combo boro/rba on it.
With 3 of them when i press fire appears 'Reply Ready' on the screen but with the other one the message don't appear on screen but all works fine anyway, i can vape without problem.
Do you know why this behaviour?
Atoms are build with single wire ka1 or ni70.
Thaks guys.
Sure. Replay works best with a proper TC material like SS.
You are quite lucky to get a 'replay ready' with N70. You must use enough watts or long puff for the mod to be able to capture the puff. I will assume the 4th that does not show 'replay ready' is your kanthal coil with the flattest/lowest change in resistance.
  • Wayneo changed the title to Replay on dna80c with different atomizer
Thanks Wayneo
Yes the atom (Serin Rba) that doesn't show "Replay Ready" has build with ka1 6 wraps 2.5 28 awg, actually the same build on kayfun bb shows the message but has build wit 5 wraps of the same wire.
use 12w for all atom
Edited by Millo76
Do you actually use Replay? enabled after seeing the ready? During testing I vaped a N80 coil and wick perfectly dry with no burn. 30+ puffs from when the rda was dry. I got nic sick thinking it would be much fewer puffs. It never burned/singed the cotton.
