Hallowplay Posted February 25 Report Posted February 25 I've been using killite on a dna 60 board for more than 2 months now, and I've been using it carefully. There is a problem reducing the power as if the board itself presses the button - despite the new battery and holds the charge normally, but the problem is serious, it does not respond to the fire button. during power reduction . I hope the board is not dead and you can do something, because the device is not cheap.
Hallowplay Posted February 25 Author Report Posted February 25 an important clarification is that it has never been opened, so perhaps cleaning the board will help
Wayneo Posted February 25 Report Posted February 25 If this is what your mod looks like, remove the panel over the fire button and see if the problem still exists. Is that a color screen on the mod? You can also (with mod plugged in) use escribe - Device Monitor and the bottom line will show what buttons are being pressed. Sounds like a stuck 'down' button, but is it from the board or panel.
Hallowplay Posted February 25 Author Report Posted February 25 No, it's not colored, I don't have a pro version.
Wayneo Posted February 25 Report Posted February 25 Post moved to proper area. What I typed still stands. Thank you.
