SkarnUlfr Posted January 4 Report Posted January 4 my coil is 1.28 ohms for some reason on my mod it misses the one out and only reads .28 Its was fine when i created it and when i set back to default it works but every time i upload the theme now it changes? is this a bug?
Wayneo Posted January 5 Report Posted January 5 Big difference between 'reads' and 'displays', but let's check. Using your theme, post a photo of the screen showing ohms, and then in escribe, start device monitor and post a screenshot.
SkarnUlfr Posted January 5 Author Report Posted January 5 (edited) Edited January 5 by SkarnUlfr wrong pic uploaded
SkarnUlfr Posted January 5 Author Report Posted January 5 (edited) heres the screen Edited January 5 by SkarnUlfr
Wayneo Posted January 5 Report Posted January 5 So it's a display issue. Either you're trying to show too many digits after the decimal or the field is just too small,.
SkarnUlfr Posted January 6 Author Report Posted January 6 (edited) reply neither the field is the default size and i never changed how many digits it shows like i said before it was working normal then just suddenly happened to go like this. also if i redesign the whole theme like i did last night it goes back to normal then after a while it happens again . i mean its not realy important since i always use an ohm meter to rate my coils but its not how its intended to run . Edited January 6 by SkarnUlfr
Wayneo Posted January 6 Report Posted January 6 The evolv default theme shows ohms on 4 different 'pages' (that you said showed your '1.x'). Here are 4 screenshots with each 'ohm' field highlighted/selected. Show me the same from your theme or just the missing '1' pages. Thanks.
SkarnUlfr Posted January 6 Author Report Posted January 6 i think i figured out the problem when i changed the small font it disappears the first number i set it back to the original font and it comes back .
