kzerwu Posted January 5 Author Report Posted January 5 Still working incorrectly, I am using Wireoptim's SS316L coil, 28ga, 2.5 diameter, 5 turns 工作仍然不正确,我使用的是Wireoptim的SS 316 L线圈,28 ga,2.5直径,5圈
Wayneo Posted January 5 Report Posted January 5 Too many changes going on by you. A shifting landscape where you just guessing as you make changes arbitrarily. So for your last 2 posts, although I posted a screenshot of the exact 7 checkboxes I wanted you to enable, YOU did not. Then you throw in a whole new coil with a new resistance without mentioing if it was dry burned and glowing evenly from the center out. Out of sequence puffs and mismatched profiles do not help either. The intricacies of getting TC to work properly are relatively simple, with barely any manipulation required. I cannot help you any longer. You are free to open a Help Desk ticket, link in my signature line. I will help you with 'Replay' which is much simpler to use and provides dry burn protection like TC, if you wish.
