executed Posted January 2 Report Posted January 2 By reading forum I came to conclusion that DNA80C might have limited Escribe config options compared to other boards. I guess it has something to do with TC options. That leads me to suspicion that Serial commands support is also not full in other areas, not only TC. I don't have 80C device yet, so I would like to ask on forum before buying one about command availability on DNA80C based on unofficial supported command list I found on Github. - Do you guys know which of these commands might not be supported on DNA80C? - If answer is not trivial, can you at least tell me if following 2 are supported? S=GET PUFFS & P=<number>W (Set power).
Wayneo Posted January 2 Report Posted January 2 1 hour ago, executed said: limited Escribe config options compared to other boards. I guess it has something to do with TC options. Limited yes, and there are no TC options. 1 hour ago, executed said: Do you guys know which of these commands might not be supported on DNA80C? Both are supported by serial commands, and both are also visible on the mod. 1
