I am using Lost Vape Hyperion DNA 100C with SS904L  0.2 ohms in a Crown IV tank. The mod has SS316 and SS430 settings. Which setting do I use for the SS904L coils?
I'd suggest you use Replay with 'watts' set as the material type for best results.
You could download the SS904 material file (I believe) from steam-engine, but even then your coil probably has Nickel legs which throws off the proper values of the material file.
