Drako Posted August 18, 2025 Report Posted August 18, 2025 I just bought the device amd normally i carry around 2 cartridges with 2 different flavors and i just found out that removing the cartridge cancels the replay i set when i pressed the replay button. Is there a work around for this?
Wayneo Posted August 18, 2025 Report Posted August 18, 2025 Your mod is working as intended. There is no workaround. Even if you were to remove, fill and replace the same pod, you'll need to reactivate replay.
Drako Posted August 18, 2025 Author Report Posted August 18, 2025 I didn't mean my mod isn't working as intented, i am just saying is there a work around to keep my replay saved if i removed the pod. Am a beginner with escribe but can i save the puff i replayed and make it my default through escribe?
Drako Posted August 18, 2025 Author Report Posted August 18, 2025 (edited) Then what's the point of having a DNA chip? I mean if i can't set a replay or a curve then whas is the point of the DNA chip? Is it just the Anti burn feature? Edited August 18, 2025 by Drako
