For those experiencing spurious Fill Pod messages, try the attached settings. ->  Low Sensitivity Fill Pod.ecig
These settings lower the fill pod sensitivity.  Please let me know if these settings alleviate the issue.
Installation Instructions.
Start escribe with your OXVA DNA already plugged.
Do a 'file -> open' of the .ecig file you downloaded from above.
Then click 'Upload settings to mod'
  • Brandon changed the title to Low Sensitivity Fill Pod Settings File
On 8/17/2025 at 12:43 PM, dannyh said:
I wasn't seeing fill pod that much on a .8 until I installed this
Well, that certainly wasn't the intention.  Check your DM's.
same issue, it happened on a new pod after installing this
Can we have some insight as to why we think this might be happening? The inconsistency of the error is probably the most frustrating. I have this happening on all pod types (.8s and 1.2s). I'll pick up the device and it either works as intended, or requires 3-4 puff n fiddles (wipe off the contacts, slide the pod in and out, rotate the pod) then it works just fine, multiple rips in a row, pod warmed up etc.
I am lead to believe its a pod issue, as it seems when i put a new pod in I get ~1500 puffs or so before goofiness starts occurring. SOMETIMES backing a volt off clears up the issue, which leads me to believe that I'm vaping within the performance window, and the pod is possibly dropping resistance?
However, I will note that I struggle to recreate the issue when plugged in... I guess I am wondering if its more of a resistance triggering a fault, or a battery safety trigger? Battery safety would (in my mind at least) explain why the issue is not prevalent when plugged in.  If I am able to generate the fault reliably while plugged in I will try to record on escribe.
Well, just as I posted the device cooled down, and i was able to repeat multiple failed puffs. Pt2 includes additional values i neglected to record in 829csv. P2 also includes a "pod fiddle" and resumption of successful vaping. Hope this helps in some way!
829pt2.csv 829.csv
how you instile this file 829pt2?is a csv file ,different than ecig file ?please advise.
Thank you
