For those experiencing spurious Fill Pod messages, try the attached settings. ->  Low Sensitivity Fill Pod.ecig
These settings lower the fill pod sensitivity.  Please let me know if these settings alleviate the issue.
Installation Instructions.
Start escribe with your OXVA DNA already plugged.
Do a 'file -> open' of the .ecig file you downloaded from above.
Then click 'Upload settings to mod'
  • Brandon changed the title to Low Sensitivity Fill Pod Settings File
On 8/17/2025 at 12:43 PM, dannyh said:
I wasn't seeing fill pod that much on a .8 until I installed this
Well, that certainly wasn't the intention.  Check your DM's.
Can we have some insight as to why we think this might be happening? The inconsistency of the error is probably the most frustrating. I have this happening on all pod types (.8s and 1.2s). I'll pick up the device and it either works as intended, or requires 3-4 puff n fiddles (wipe off the contacts, slide the pod in and out, rotate the pod) then it works just fine, multiple rips in a row, pod warmed up etc.
I am lead to believe its a pod issue, as it seems when i put a new pod in I get ~1500 puffs or so before goofiness starts occurring. SOMETIMES backing a volt off clears up the issue, which leads me to believe that I'm vaping within the performance window, and the pod is possibly dropping resistance?
However, I will note that I struggle to recreate the issue when plugged in... I guess I am wondering if its more of a resistance triggering a fault, or a battery safety trigger? Battery safety would (in my mind at least) explain why the issue is not prevalent when plugged in.  If I am able to generate the fault reliably while plugged in I will try to record on escribe.
Well, just as I posted the device cooled down, and i was able to repeat multiple failed puffs. Pt2 includes additional values i neglected to record in 829csv. P2 also includes a "pod fiddle" and resumption of successful vaping. Hope this helps in some way!
829pt2.csv 829.csv
41 minutes ago, Cristianbuta said:
how you instile this file 829pt2?is a csv file ,different than ecig file ?please advise.Thank you
NOT a file for you to install.
Are any of you having success with the file posted above (top, 1st post)?
what resistance coil?
what power setting?
replay yes/no?
what firmware (bottom right hand corner of escribe - Device Monitor)?
Hi Wayneo, unfortunately it doesn't seem to make a difference in my specific case. The logs attached were with the prescribed settings, I have since rolled back to "stock". I tossed the 1.2 pod I was using into the trash and currently 1500+ puffs into a new pod without a single fill pod warning.
Thanks for that reply @magman007
what power setting?
replay yes/no?
Not using the above settings, back to stock (default)
And no errors with a new coil
I’ve been experiencing this less in general especially since the .8 just burns the coil instead. I have 1 device with this update on it and 1 that doesn’t and didn’t notice a difference switching off
  • Thanks 1
what resistance coil? 1.2ohm
what power setting? ~happened between 12-14w- The logs attached earlier in the thread
replay yes/no? No- however I did experiment to see if replay would circumvent the issue, it didn't
what firmware (bottom right hand corner of escribe - Device Monitor)? 1.1 SP 112.2 INT
Hey Wayneo, answers above- Not sure if the CSV's i attached earlier are helpful, but I did capture the fault in those logs consistently.
oddly enough, I did notice that the issue seems to subside once the coil head heats up? kinda... once its rolling its good to go until it cools off again. I don't know enough about the coil heads or stainless steels material properties, does it make sense for SS to increase resistance when warm?
That firmware is 2 updates shy of the current. Download and install this one. It will also inform you of future updates. You need to go under 'tools' to install it. SP68
Yes, SS does raise its resistance when you puff, and drops back down as it cools.
Thanks for the Firmware update, Will test and report back.  I found it very difficult to find any information on the firmware, version or currency. If you have open communication with Oxva I would recommend they update their documentation in the goggle drive.
That firmware does not address this issue, just what you read for the past 2 versions, and updates are always posted here. I have never had any communication with Oxva, and know nothing about documentation in their goggle drive (or even if it's accurate). DWCraig and I (among others) have been testing these since February.
Understood that the new FW will not address the pod fill issue, but will address previous known issues, and for that I am grateful!
the mediakit can be found here
https://www.oxva.com/pages/download
https://drive.google.com/drive/folders/10tF2nLOlxEu9ujhNC5WGZYi7QUKG30_B
it looks like the last updates were may, so no it is not up to date or accurate.
I do not want to flood the thread with more unsolicited feedback, but even a link on the evolv home page to the most current firmware would be helpful. I realize the chinese ecig industry isnt really predicated on support, but seeing as this has evolv's name proudly co-branded it would bode well to consider providing that layer of support/accessibility oxva doesn't seem interested in doing. Knowing Sp68 will notify of new versions should nullify this need for those with it installed, but a new user will probably find themselves in the media kit above and downloading a 2 version old firmware and outdated escribe, just as I did :D
Lastly, thank you for your testing and the support provided! I know its not easy and its often thankless.
Even updating too the SP69 and using this it still is giving me the same issues - "fill pod" even though my pod is filled im using the 0.8 stainless steel pods and yes i have tried multiple pods and waited 5 - 10 mins after each fill to make sure the coil is saturated.
after i do take a good hit and it registers and doesnt say "fill pod" i can put it in replay mode and the issue doesnt happen anymore until i have to take the pod out.
the flavours with the stainless steel 0.8 pods and the way it hits is so much worst compared to the normal 0.8 pods the OXVA pro 2 use.
luckily i still have some 0.8 non stainless steel pods so i can use these until this issue is fixed it seems like more off a pod issue compared to the actual software from what i can tell because the OXVA PRO DNA 2 works just fine with the non stainless steel pods, its just very disapointing that i brought this vape for the anti burn and replay but i cant even use it because the pods were not made correctly.
SP69 adds trace recording (showing the actual puff waveforms... well, a 8 Hz version of them).
If you sync your puffs with ECigStats, what do you get for the puffs that say Fill Pod? Could you click "Download Puff" for the particular puffs and attach the CSV files here? Thanks!
  • 1 month later...
Hello fellow sufferers,
despite the new settings and a firmware update, I still keep getting the “fill pod” message. No matter how many times I change the pod, the problem starts again after a short while. What kind of crap is this?
