Nicola420 Posted April 25, 2025 Report Posted April 25, 2025 Ciao a tutti ho.provato a cercare nel sito ma non ho trovato nulla e volevo chiederv se in pratica è normale che la mia dna250c rilevi la temperatura ambiente solo al momento in cui rimetto le celle cioe vado a riavviare e poi se svapo questa si blocca mentre continua a salire o scendere quella della board
Wayneo Posted April 25, 2025 Report Posted April 25, 2025 In normal usage the ambient temp is pretty flat, but it will change. It really only matters if you are a TC vaper. When you put cells back in, it also re-reads the resistance of your coil. 1
Nicola420 Posted April 25, 2025 Author Report Posted April 25, 2025 Sono d accordo ma quello che mi chiedevo è se era normale che la temperatura della room non si aggiorna più dopo che schiaccio fire mentre quella della board si aggiorna sempre
Nicola420 Posted April 25, 2025 Author Report Posted April 25, 2025 Per farla aggiornare devo riavviare la box toglielo le batterie
Wayneo Posted April 26, 2025 Report Posted April 26, 2025 2 hours ago, Nicola420 said: I agree but what I was wondering is if it was normal that the room temperature no longer updates after I press fire while the board temperature always updates OK, so think this through. When you hit the fire button, batteries generate heat (but this doesn't count) as well as inductors on the back of the board. That's where the majority of the heat comes from. 3 hours ago, Nicola420 said: To update it I have to restart the box by removing the batteries Stop doing that. The programming on the board is doing all that.
Nicola420 Posted April 26, 2025 Author Report Posted April 26, 2025 Curiosità mia Nella tua dna la temperatura room si blocca quando premi fire?
Wayneo Posted April 26, 2025 Report Posted April 26, 2025 Come on man, when I vape my room temperature does not change. I do not expect the room temperature to change. When I press 'fire' I can't even see the screen. Why do you think it should change?
Wayneo Posted April 26, 2025 Report Posted April 26, 2025 AND ........... 19 hours ago, Nicola420 said: Ciao a tutti ho.provato a cercare nel sito ma non ho trovato nulla e volevo chiederv se in pratica è normale che la mia dna250c rilevi la temperatura ambiente solo al momento in cui rimetto le celle cioe vado a riavviare e poi se svapo questa si blocca mentre continua a salire o scendere quella della board
Nicola420 Posted April 26, 2025 Author Report Posted April 26, 2025 31 minuti fa, Wayneo ha scritto: Dai, amico, quando svapo la temperatura ambiente non cambia. Non mi aspetto che la temperatura ambiente cambi. Quando premo "fire" non riesco nemmeno a vedere lo schermo. Perché pensi che dovrebbe cambiare? A me neanche dopo 10 ore cambia Per farla cambiare devo aggiornare e vedere che legge quella ambientale
Nicola420 Posted April 26, 2025 Author Report Posted April 26, 2025 (edited) Per farla aggiornare come ti dicevo lascio le batterie in carica poi quando le inserisco la temperatura è finalmente giusta ma appena svapo la temperatura non si alza più L unica temperatura che varia è quella appunto della board Edited April 26, 2025 by Nicola420
Wayneo Posted April 26, 2025 Report Posted April 26, 2025 Yup, gonna lock this thread. Re-read what I have posted. If you still have concerns, please open a 'Help Desk' ticket. ⬇️ Link in my signature line. ⬇️
