Annatar Posted March 31, 2025 Report Posted March 31, 2025 Hi Community, I am David, 45, and a huge DNA fan since years. At the moment I have a strange issue with my Dovpo Odin DNA. The Dovpo has been unused for a while now. Yesterday I wanted to reactivate it. I set the Replay Mode, take 2 or 3 good puffs until I get a good taste. Then I save the puff and everything seems okay. But when I now take a saved puff there comes hardly any power or vapor- nothing like the previously saved puff. It seems as if the Dovpo is completely reducing the power. If I delete the saved puff, the Dovpo behaves normally until I save again. Then the power is again reduced. This problem occurs with different atomizers and different mesh/ resistance. Does someone has an idea what the root cause might be? Greetings from Germany and happy vaping. 😉
Wayneo Posted April 1, 2025 Report Posted April 1, 2025 Can you post a FULL Device Monitor screenshot showing only the 5 fields in the image below. 2 puffs, 1 before Replay, and 1 when the problem occurs. Also a full screenshot of the profile you're using. I might as well ask what theme is on your mod? Thanks
Annatar Posted April 1, 2025 Author Report Posted April 1, 2025 @Wayneo Yepp, good idea. I will connect the Dovpo tomorrow and post the screenshots. Thanks for your quick response. 🙋♂️
Annatar Posted April 1, 2025 Author Report Posted April 1, 2025 Okay, the "Rubber Duck Debugging" worked fine... 🙃 I have checked my profiles and just changed the current profile to "Profile 1 - Replay". Now the Dovpo works as it should. No plan, why the Profile 8 did such strange things. Thanks @Wayneo for your input! 🫣 Greetings; David 1
Wayneo Posted April 1, 2025 Report Posted April 1, 2025 Glad you're all set and working fine. Your Profile 8 might have the 'enable replay' box checked. Many well intentioned Theme Designers allow Replay to work when a TC material is chosen which causes crazy shit for unsuspecting users. 1
