AuthorVapes Posted November 9, 2024 Report Share Posted November 9, 2024 Is the lock resistor necessary when using the temperature control function? Also, why can't I set the room temperature? Link to comment Share on other sites More sharing options...
Wayneo Posted November 9, 2024 Report Share Posted November 9, 2024 Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable. Link to comment Share on other sites More sharing options...
AuthorVapes Posted November 10, 2024 Author Report Share Posted November 10, 2024 8 小時前, Wayneo說: Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable. "The room temp is read with the resistance, but you can make it changeable. " Re: Can this be implemented in the theme? I added the "Room Temperature" field but it is not editable. Link to comment Share on other sites More sharing options...
