I have two questions: Regarding the "TC" function of DNA60C
Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available.
Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable.
8 小時前, Wayneo說:
"The room temp is read with the resistance, but you can make it changeable. "
Re: Can this be implemented in the theme? I added the "Room Temperature" field but it is not editable.
