AuthorVapes Posted November 9, 2024 Report Posted November 9, 2024 Is the lock resistor necessary when using the temperature control function? Also, why can't I set the room temperature?
Wayneo Posted November 9, 2024 Report Posted November 9, 2024 Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable.
AuthorVapes Posted November 10, 2024 Author Report Posted November 10, 2024 8 小時前, Wayneo說: Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable. "The room temp is read with the resistance, but you can make it changeable. " Re: Can this be implemented in the theme? I added the "Room Temperature" field but it is not editable.
