Overkill Posted August 16, 2024 Report Posted August 16, 2024 hello! I got a san aio yesterday and spent a while building it over and over while getting it working right. originally it was measuring the coil correctly around .6. at some point it measured the coil as .9 and won't let the measurement go. replay does not work right at this resistance. the dna60c has a way to measure the coil specifically and in the past with a dna60 reading the settings into escribe and then writing them out again would prompt a new coil measurement. I am currently cooling the device at 70 before trying that. does anyone have a good way to force the dna80c to measure the coil again? I am hoping that once I do this once that the 80c will be stable enough that it will hold onto the right measurement for a long time
Overkill Posted August 16, 2024 Author Report Posted August 16, 2024 reading and writing the settings seems to work, however I only got the resistance down to .86. the vape still hits great, but if I try to turn replay on and fire it I start getting check atty messages. I don't recall this happening when the coil was reading .6 but I have only had the device for a day so maybe there are other things going on?
Wayneo Posted August 16, 2024 Report Posted August 16, 2024 "how to force a coil measurement?" Or just yank the battery You can see our/the troubleshooting steps here. https://forum.evolvapor.com/topic/72256-replay-dna-80c/
Overkill Posted August 16, 2024 Author Report Posted August 16, 2024 thank you! just yanking the battery didn't seem to be enough. I will read that link thank you!
