Wayneo Posted August 5, 2024 Report Share Posted August 5, 2024 Download new theme Start escribe with mod plugged in. Go to theme -> Load theme (Select theme you just downloaded) choose 'Open' (on a Mac) Then 'Upload Settings to Device' <- Most important thing 😉 A theme also includes the following screen behavior fields Active time, Idle Time, Fade-In, and Fade-out time. <- If you don't like any of the 4, change it yourself. Under the Language Tab are short forms for messages. If you don't like them, change them BUT if you want to report an issue you need to use the long form, or the default Evolv short-forms. After you've done it a few times, there is a quicker way by just starting escribe, then 'Theme Designer' immediately. 1 Link to comment Share on other sites More sharing options...
