Dan87 Posted July 21 Report Share Posted July 21 Hello, just got my first device with DNA chip, it's a SAN AIO with the 80c chip. i just can't get the replay mode to work consistently, i'm using Vaporesso GTX 0.8 ohms mesh coils. Some coils allow it, some others don't. The one i'm currently using has never given me the chance to enable replay mode. I tried searching online for anwsers but had no luck. Also tried looking for documentation about the chip but can't find that either. Any help please? Link to comment Share on other sites More sharing options...
Wayneo Posted July 21 Report Share Posted July 21 You will always get better results using proper/consistent Replay usage using a TC capable material (wire, such as SS) in an RBA. I have used chunky N80 (non TC) clapton coils in Replay successfully. I have used those Vaporesso coils also. At a minimum you need a solid positive and negative connection. It could be down to even the flushnut you're using, or the boro(tank) itself not allowing a great connection. 1 Link to comment Share on other sites More sharing options...
xu7jp4 Posted Saturday at 03:35 PM Report Share Posted Saturday at 03:35 PM Possible to disable "replay mode" icon etc...? Link to comment Share on other sites More sharing options...
Wayneo Posted Saturday at 06:31 PM Report Share Posted Saturday at 06:31 PM No, not the way you'd think. You can zero out the field location and icons but You would need to check it all works the same. Why would you or anyone else want to remove 'Replay' from the mod? There are other 80 watt mods on the market with different boards, and cheaper. Link to comment Share on other sites More sharing options...
xu7jp4 Posted Saturday at 06:48 PM Report Share Posted Saturday at 06:48 PM I'll test it 👍🏻 Cheap chipset are very Bad for vaping.... Mine is Parsons Vaperz cloud Sbs with Taifun Gx 60w/70w 🫣 If anyone Can share theme tita X2 veepon or original theme dna80c 👀 Link to comment Share on other sites More sharing options...
Wayneo Posted Saturday at 08:08 PM Report Share Posted Saturday at 08:08 PM You can download the default theme from within escribe while your mod is plugged in, when it first starts up. Why do you want to remove 'Replay'? I use it with my 3 Taifun GX's just fine, even with Nichrome, SS, and Titanium. Link to comment Share on other sites More sharing options...
xu7jp4 Posted Saturday at 08:31 PM Report Share Posted Saturday at 08:31 PM (edited) I have my original theme but not the others I use ni80 and replay don't work.... Edited Saturday at 08:32 PM by xu7jp4 Link to comment Share on other sites More sharing options...
Wayneo Posted Saturday at 10:21 PM Report Share Posted Saturday at 10:21 PM 1 hour ago, xu7jp4 said: I use ni80 and replay don't work.... Try taking a longer puff, like 3 seconds. Describe your coil? I run my GX's at mid 40's, 2x24/32 n80. Link to comment Share on other sites More sharing options...
