bronsom78 Posted March 9, 2024 Report Posted March 9, 2024 Hi, I run into the problem that when the mod is inactive after approximately 1 hour, the screen turns on by itself. The mod does not fire itself and the wattage is not altered either. All wiring and soldering are clean, write too. I have this same fault in three electronics. Can someone help me, since this is making me desperate... I have built many dozens of mods using DNA60 and this has never happened to me. Thanks for the support!
Wayneo Posted March 9, 2024 Report Posted March 9, 2024 A couple questions? Actually 3. Are the 3 mods made by you? Do they use the on-board buttons, or external buttons? Do they have USB ports? 1
bronsom78 Posted March 9, 2024 Author Report Posted March 9, 2024 Hi, all three made by me. No usb, external up and down.
bronsom78 Posted March 9, 2024 Author Report Posted March 9, 2024 Hace 7 minutos , Wayneo dijo: A couple questions? Actually 3. Are the 3 mods made by you? Do they use the on-board buttons, or external buttons? Do they have USB ports? external buttons pcb connected to pin 1, pin 6 and ground
Wayneo Posted March 9, 2024 Report Posted March 9, 2024 I have not seen that issue myself, and it does seem odd. I'd suggest you de-solder those 3 connections on an offending mod and see if the issue persists. If it does re-occur, open an official help desk ticket (link in my signature line). 1
