Rotaku Posted November 24, 2023 Report Share Posted November 24, 2023 Hello everyone, so i'm new using DNA device, I'm using thelema dna 250c with rda dead rabbit v2 and coil MV Baby alien I have a strange problem which whatever coil i used the taste is so not good, like it burnt but it's not. I already 3 times change the coil and borrow my friend rda which is dead rabbit v2 too, but still have the same problem. Do this thelema dna just picky about rda and coil? or my device has the problem? because this device i purchase secondhand. Anyway i already escribe it and restore default settings too. Thx Link to comment Share on other sites More sharing options...
Wayneo Posted November 24, 2023 Report Share Posted November 24, 2023 Easy Answer: Turn down the watts. Longer Answer: Do a FULL screenprint of your current profile in escribe, like this and answer the 3 questions below. Did you try your DRv2 on your friends mod? And how was it? What material (wire) are your coils? Link to comment Share on other sites More sharing options...
Rotaku Posted November 24, 2023 Author Report Share Posted November 24, 2023 (edited) Ok like this ? And about turn down the watts you mean while vaping or wicking cotton ? I already try my rda on my friend mod but not problem, anyway his mod is rincoe manto pro not an dna device. About material i dont really know but this is the description "Handcrafted Premium Coils Made with @twistedmesses Wire N80 .. inner wire on all series come with 27/28/29/30/32 Awg and 36/37/38 Awg for outer wire" also thx for replying Edited November 24, 2023 by Rotaku add image Link to comment Share on other sites More sharing options...
Wayneo Posted November 24, 2023 Report Share Posted November 24, 2023 Yes, excellent. And turn down the watts while vaping. From your Profile 2 settings, with the DRv2 you are using everything basic. Any/every mod with no sort of boost, with fresh batteries should be almost identical at 55 watts. Every atty/RDA you need to check/prepare the coil before wicking. Low glow dry burn and check for hotspots Because it's an RDA you need to keep those wicks juiced up between puffs (5, 10, 12 puffs). I can't see it being your mod or RDA. 1 Link to comment Share on other sites More sharing options...
Rotaku Posted November 25, 2023 Author Report Share Posted November 25, 2023 Ok thx for your advice, i think low glow dry burn and turn down the watt should do the trick Link to comment Share on other sites More sharing options...
