accpaul Posted September 20, 2023 Report Posted September 20, 2023 Can someone help me understand why is this happening and help me fix it? i have a ZQ Essent with DNA75c and any theme i use or even if i create my own, all items on screen are stretched horizontally although in theme designer it looks normal. if i shrink the images by around 10% on vertical, then they will appear normal when i upload to the device.
Wayneo Posted September 20, 2023 Report Posted September 20, 2023 46 minutes ago, accpaul said: ......... any theme i use or even if i create my own, all items on screen are stretched horizontally although in theme designer it looks normal. It always been like that. I'd always use an external tool to manipulate images. Mainly noticed when using round/circular images. 1
accpaul Posted September 21, 2023 Author Report Posted September 21, 2023 14 hours ago, Wayneo said: It always been like that. I'd always use an external tool to manipulate images. Mainly noticed when using round/circular images. wow that is so strange, i did not expect that 😅 mkay then, will continue doing the same Thanks for the reply, Wayneo
aleix_9 Posted January 21 Report Posted January 21 This usually happens due to a screen resolution or DPI mismatch between Escribe Theme Designer and the actual DNA75C device display. The ZQ Essent uses a slightly non-square pixel scaling, so themes that look correct on PC preview appear horizontally stretched on-device. The practical fix is to design with a small vertical scale reduction (as you did) or explicitly set the correct screen dimensions and disable DPI scaling in Theme Designer before exporting.
