thelateoctober Posted February 23, 2023 Report Posted February 23, 2023 So I'm rebuilding an old mod. Upgraded from 200 to 250. I've got a Hammond 1t90b enclosure. Wall dimensions are as they should be, 2mm. I got actuators from Alpinetech, 1.5mm flange. I'm test fitting the board into the enclosure to measure power/ground in and out. With the board snapped into the holder (also Alpinetech), and the actuators in their holes, when I press the holder flush against the enclosure wall as it would be when installed, all of the actuators are depressed enough that all 3 onboard buttons are depressed. I can't figure out what is going on. This is not my first build by any means, not my first 200 to 250 conversion, and I've never seen this problem. I will say - when I first took it apart, the screen was attached to the board mount with a piece of double sided foam tape probably 2mm thick, so sticking out from the board mount rather than being flush like normal. The actuators also had very thin, maybe 0.5mm plates on the back of each, adding additional length to the actuators. I have no idea what this guy did or what is going on. Does anyone have any insight here? Thanks in advance.
dwcraig1 Posted February 23, 2023 Report Posted February 23, 2023 Alpintech sell two different actuator button lengths.
thelateoctober Posted February 23, 2023 Author Report Posted February 23, 2023 (edited) 3 minutes ago, dwcraig1 said: Alpintech sell two different actuator button lengths. It's the 1.5mm flange on the inside that's the problem, not the length of the switch. E: actuator, not switch Edited February 23, 2023 by thelateoctober
thelateoctober Posted February 23, 2023 Author Report Posted February 23, 2023 I'm just going to buy some shims to put between the holder and the enclosure and call it a day. 1
dwcraig1 Posted February 23, 2023 Report Posted February 23, 2023 I would guess that the holder is the problem then.
Phoenix Box Mods Posted March 31, 2024 Report Posted March 31, 2024 (edited) shave the buttons - do not shim the holder - the holder should be flat when epoxy is added to make sure it holds tight when usb is pulled in and out - sand the buttons simple fix Edited March 31, 2024 by Phoenix Box Mods
