alsk1 Posted December 13, 2022 Report Share Posted December 13, 2022 I found an error in the Escribe Software. But my english is not the best to explain.... If you import a new Coil Material with a long filename (e.g. "Nife30_Resistherm_TCR_SteamEngine_xxxx.csv it works... But when you download the settings from the mod, the name of this material is changed to "Nife3" and this Material is double in the mod under both names (old name and new name). Link to comment Share on other sites More sharing options...
Wayneo Posted December 14, 2022 Report Share Posted December 14, 2022 Alrighty then, here's the info required to help you. What board type are you using. Color or black and white. What do you mean by this? ⬇ Where do you see it. 20 hours ago, alsk1 said: But when you download the settings from the mod, the name of this material is changed to "Nife3" What do you mean by this? ⬇ 20 hours ago, alsk1 said: this Material is double in the mod under both names (old name and new name). It might be easier if you post a couple screenshots for me to see. 1 Link to comment Share on other sites More sharing options...
alsk1 Posted December 15, 2022 Author Report Share Posted December 15, 2022 vor 12 Stunden schrieb Wayneo: Alrighty then, here's the info required to help you. What board type are you using. Color or black and white. What do you mean by this? ⬇ Where do you see it. What do you mean by this? ⬇ It might be easier if you post a couple screenshots for me to see. I use the DNA75c Link to comment Share on other sites More sharing options...
Wayneo Posted December 15, 2022 Report Share Posted December 15, 2022 I don't see the shortened filename on the right or the left. Or the duplicate file on the right side On 12/13/2022 at 6:17 PM, alsk1 said: and this Material is double in the mod under both names (old name and new name). Everything else is normal. No issue. If you post THAT screenshot (short name), do not write text on it. Link to comment Share on other sites More sharing options...
alsk1 Posted December 15, 2022 Author Report Share Posted December 15, 2022 The screenshot was to show in which menu it happens. You can't see the problem on it, because i deleted the double names (original and shortened) and imported the files with short filenames.... Link to comment Share on other sites More sharing options...
Wayneo Posted December 15, 2022 Report Share Posted December 15, 2022 @alsk1 I do not believe there is a bug (I could be wrong), and I am going to move these posts about this to their own topic. Since you have cleaned up the issue there is nothing more I can check. Nothing will be removed, just moved. Feel free to create new topics at your leisure in the relevant forum. 1 Link to comment Share on other sites More sharing options...
