Marco234 Posted October 29, 2022 Report Posted October 29, 2022 for my mod there is a mode called replay.......if i decide to use that without the playing feature what happens? What happens if i decided to use the "playing" feature? Thanks alot
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 I suppose playing is also called "save puff"
Wayneo Posted October 29, 2022 Report Posted October 29, 2022 First you’ll see the ’save puff’ and if you click the center button you’ll see playing. save puff just means the mod will attempt to replicate the puff you just took and playing means it’s working. If you don’t hit save it will merrily go along just fine.
Wayneo Posted October 29, 2022 Report Posted October 29, 2022 All color boards effectively work the same and there is nothing vendor specific about any of them. Maybe an odd feature or 2 but the 250C is the most rich in features.
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 4 minutes ago, Wayneo said: All color boards effectively work the same and there is nothing vendor specific about any of them. Maybe an odd feature or 2 but the 250C is the most rich in features. what is replay mode in essence though exactly
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 assuming i don't use the save puff feature
Wayneo Posted October 29, 2022 Report Posted October 29, 2022 Replay mode says to the mod ……. Start internally keeping track of these puffs and when I think yeah Buddy ….. use that puff and try to replicate it for me. In other words, replay it. If you never hit save then it just fires at whatever watts you set.
Wayneo Posted October 29, 2022 Report Posted October 29, 2022 If you do save a good puff it will save you from dry hits and you could actually vape till your tank is empty and your cotton almost dry
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 so replay mode without saving the puff is just like wattage mode basically.
Wayneo Posted October 29, 2022 Report Posted October 29, 2022 Yes. But if you’re using a coil capable of replay why wouldn’t you use it ?
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 6 minutes ago, Wayneo said: Yes. But if you’re using a coil capable of replay why wouldn’t you use it ? my coil is a ceramic .3ohm SS316(VAPORESSO I GT CORE) coil.....i try using it on the SS316 mode but it seems to not really work really and give weak hits......would replay be a solid replacement for this or just general use
Marco234 Posted October 29, 2022 Author Report Posted October 29, 2022 if it wasn't a temp sensing coil would save not show up?
