Is there a way I can copy the settings of a different mod.
jsd540
I'm using Kanthal A1 26GA Round wire 7 wraps 0.98 to 1.1 ohms. I would like a curve similar to the asmodus curve which never pops and coils last at least a week. For some reason even with 0 boost in watt mode my coils burn out and juice pops. Like one strong pop. Not sure what I'm doing wrong. Any help is appreciated.
There is no wattage curve. But, in a Profile where a NON TC material has been selected you can do a BOOST PUNCH. It's a set 1 second slider. Effectively a hard normal soft like other mods, to give a coil that extra to start vaping quicker.
You might want to turn your watts down a bit, with Punch at 5, and work the punch up or down. That might delay burning your coil.
EDIT: What kind of mod? You've posted this in the 'Reflex' area
