Marchelly Posted March 9, 2022 Report Share Posted March 9, 2022 Hey all, I have a Lost Vape Centaurus with the DNA 250C chipset. I haven't be able to connect to eScribe. I have tried different USB cables and even different computers and it is not working. My desktop is currently on Win10 and I have tried running as an administrator with no joy. Thanks! Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 9, 2022 Report Share Posted March 9, 2022 I'd start with using a phone or some other device that uses data to verify the cable does data. Earlier versions, EScribe 1.2 will not work with the color boards, it must be 2.0 https://downloads.evolvapor.com/SetupEScribe2_SP30_INT.exe https://downloads.evolvapor.com/SetupEScribe2_SP31_INT_ServicePack.exe Link to comment Share on other sites More sharing options...
compile Posted March 12, 2022 Report Share Posted March 12, 2022 I have the same issue. I've tried different cables, different devices with said cables (which work). It either doesn't work at all or get the Windows USB malfunction error. I've tried using 3 different PCs (2 are Windows 11, 1 is Windows 10) and nothing works. Link to comment Share on other sites More sharing options...
Chums1 Posted April 24, 2022 Report Share Posted April 24, 2022 When you plug it in is there little red light at the top of the screen? If not it is a bad connection. I had the same thing and when I used the new one that came with the mod it worked. Link to comment Share on other sites More sharing options...
compile Posted June 6, 2022 Report Share Posted June 6, 2022 What kind of micro USB cable is it? OTG? Are you plugging into a USB 2.0, 3.0, 3.1 port? Link to comment Share on other sites More sharing options...
