Max038 Posted February 18, 2022 Report Posted February 18, 2022 (edited) Всем привет. Надеюсь тут есть русскоговорящая аудитория) Вопрос такой: Есть Boxer classic DNA100C. Стоит дрипка на две спирали 0,12 Ом на мощность 85W вообще не жарит и выводит сообщение weak watts. Максимальный ток 20А показывает. Что не так? Какие настройки искать чтобы исправить ситуацию? Спасибо) Hello. I hope there is a Russian-speaking audience here) The question is: There is a Boxer classic DNA100C. It costs a drip for two spirals of 0.12 ohms for a power of 85W does not fry at all and displays the weak watts message. The maximum current 20A shows. What's wrong? What settings to look for to fix the situation? Thanks) Edited February 18, 2022 by Max038
Wayneo Posted February 18, 2022 Report Posted February 18, 2022 4 hours ago, Max038 said: DNA100C. It costs a drip for two spirals of 0.12 ohms for a power of 85W does not fry at all and displays the weak watts message. Weak watts is not a DNA warning. Maybe weak battery which would mean your battery is too low (in volts) to apply 85watts. Normally fixed by charging the battery or using a higher amp battery.
Max038 Posted February 18, 2022 Author Report Posted February 18, 2022 Thanks for the answer. Maybe. I'll take a look now
