Jimmothy86 Posted January 30, 2022 Report Posted January 30, 2022 So the Milwaukee M12 batteries are 3s packs, now the cells inside all packs are too low amp rated to work for this in 3s1p mode (15-16a discharge depending who you ask and which cells are actually inside). But in the larger packs, 4ah and above I believe, they are 3s2p, which would get us up to 30-32a which is sufficient for a Dna 200 however, as best I can tell, there's no circuity in the packs to limit discharge or control changing, and there's no balance plug. So is this safe? What do I need to do with the balance plug on the DNA? What battery settings do I need to set in escribe? And will the DNA handle balance charging etc just like the Milwaukee battery charger?
retird Posted January 30, 2022 Report Posted January 30, 2022 Datasheets for the 200, 250, and 250C....: https://downloads.evolvapor.com/dna200.pdf https://downloads.evolvapor.com/dna250.pdf https://downloads.evolvapor.com/dna250color.pdf 1
Phoenix Box Mods Posted March 31, 2024 Report Posted March 31, 2024 dna250 can and may use up to 28 amps in 250 and 32 on 250c so this M12 isnt a good battery for the dna board
