Frank7814 Posted December 22, 2021 Report Share Posted December 22, 2021 (edited) Hi, i bought a Hog 400 DNA 250C July, 28th . Since Friday i can´t use the device anymore. It allways schos me 12,4 -12.5 Volts. Batteries are fully charged, also with other Battery Packs. I made a factory reset but the result is the same. Any iea, what the prolem is? Or the board has a defect? Manurfactured in April this year Edited December 22, 2021 by Frank7814 Link to comment Share on other sites More sharing options...
retird Posted December 22, 2021 Report Share Posted December 22, 2021 Can you post a screenshot like this one from Device Monitor? Link to comment Share on other sites More sharing options...
retird Posted December 22, 2021 Report Share Posted December 22, 2021 Saw this Repair kit. Could that be the issue??? Not often we see a mod repair kit.... https://vaperzcloud.com/product/repair-rebuild-kit-for-hammer-of-god-v4/ Saw this also... clik on this... Also you could start a ticket with Evolv. Board has warranty from Evolv. Device does not nor do they have device parts.. What is the warranty from where you purchased this....? https://helpdesk.evolvapor.com/index.php?a=add&category=1 Also watch this.... Link to comment Share on other sites More sharing options...
Frank7814 Posted December 22, 2021 Author Report Share Posted December 22, 2021 Link to comment Share on other sites More sharing options...
Frank7814 Posted December 22, 2021 Author Report Share Posted December 22, 2021 I know, that Vaperz Cloud od´ffers spareparts,but i have a (wrong) battery indication 1. I have warranty of 1 year, the device i ordered July, 28th- 2. I can send it back to my online-shop. But it takes round about 2 weeks I don´t think, that it is a connector problem. Unfortunately, it´s the firt regulated mod since 3-4 years. All other Mods are full mechanical Mods Hog 3, Hog 3XL, HOG 4, Purge, etc. Link to comment Share on other sites More sharing options...
retird Posted December 22, 2021 Report Share Posted December 22, 2021 Great that the device maker has 1 yr. warranty. Start there. I see on the internet that the 4 posts on the battery door are soldered to the cross member metal and excessive heat can cause disconnect of 1 or more of the posts from the metal cross member. You might look there and check continuity between posts... Link to comment Share on other sites More sharing options...
Frank7814 Posted December 23, 2021 Author Report Share Posted December 23, 2021 (edited) Yes, that is normal in Germany. I´ll get another one. I cleaned the battery connectors with alcohol but it does not have any effect. With the HOG 4 (fully mechanical) i have that problem with the fire button every view month, because there is no MOSFET between batteries and fire botton as you can see in the diagram. But i don´t wand to open the battery door because of the warranty. Thank you for help!!! 😉 Edited December 23, 2021 by Frank7814 Link to comment Share on other sites More sharing options...
