i have therion DNA 75 and when i fire on 15 watt, it suddenly raise to over 30 while i use MTL tank, and when i use DL tank it fires normally over 60 as the DL is dual coil
is there any advise for firing lower than 20 W noting that same tank used on another mod working fine
Edited by John Naiem
If you're using your MTL tank right now, start escribe, then device monitor. Down on the bottom line in device monitor, it'll say Profile with a number. Click that number, or go to that profile number in escribe. Do a printscreen of that profile. Post that screen capture here.
