acop Posted March 7, 2020 Report Share Posted March 7, 2020 Hi, I am orion plus new user. Just been using for 2 days. My questions is does orion plus is limited to 18 w puff power only ? If i'm setting power more than 18 watt (Ex 20,22,24 watt) device monitor only show 18++ watt power puff only. I am using regular Regular 0.5ohm coil that come with the orion plus package. Attach screen shot of device monitor and my setting. Thanks, Acop Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 7, 2020 Report Share Posted March 7, 2020 The board has a maximum voltage output of about 3.5 volts. Your live ohms while not shown is about .7 ohms. When these figures are put into a Ohm's Law calculator the result is 17.5 watts. You can get higher wattage output by using a lower resistance coil. 1 Link to comment Share on other sites More sharing options...
