TorturedZen Posted May 3, 2019 Report Posted May 3, 2019 Once Theme Designer is opened, one of the 5 tabs that we see is Indicator Light, a function which allows you to modify the colors that will be displayed on the little LED. In some themes I've seen that the indicator colors can be modified to show a gradient effect within the color. I have tried (in vain) to figure out how that's done but nothing has worked. There are little boxes with a "+- x-<-" The Plus symbol obviously adds a color, X removes it but the arrow symbol has me confused. Is that what is needed to do the gradient...and if so, how? If not then how are the gradient colors accomplished?? And what does the arrow symbol do? If anyone knows how this works can you share your knowledge please? 1
zark Posted May 16, 2019 Report Posted May 16, 2019 В 03.05.2019 в 20:47, TorturedZen сказал: If anyone knows how this works can you share your knowledge please Чтобы получить градиент нужно 1 Выбрать цифру под прямоугольником - это продолжительность импульса 2 Правой кнопкой мыши кликнуть на прямоугольнике и выбрать цвет в выпадающем меню (клик в центре прямоугольника меняет весь цвет, клик близко к границе прямоугольника добавляет плавный переход цвета от выбранного края к центру) 3 "+" "х" добавляют (убирают) новый прямоугольник, стрелка показывает стартовый прямоугольник при использовании нескольких элементов в цветовой индикации. Больше экспериментов и все получиться, удачи! 1
John Atkins Posted May 28, 2019 Report Posted May 28, 2019 English Traanslation To get the gradient you need 1 Select the number under the rectangle - this is the duration of the pulse 2 Right-click on the rectangle and select a color in the drop-down menu (a click in the center of the rectangle changes the whole color, a click close to the border of the rectangle adds a smooth color transition from the selected edge to the center) 3 "+" "x" add (remove) a new rectangle, the arrow shows the starting rectangle when using several elements in the color display. More experiments and everything will turn out, good luck! 1
