hello, I have rebel 167w dna 250 device. I don't want to use csv for batteries. What should be the standard battery settings?
battery capacity?
cell soft cutoff?
max peak input current?
max sustained input current?
If you start escribe with no mod attached, 'edit new setting' and pick the 2 cell option, it will give/show you all the evolv default battery parameters. The csv only makes your battery % or icons more accurate. It does not affect how your mod works. I'd suggest you at least adjust the Wh setting for your battery
I'm using 2 pcs sony vtc5a in factory settings. The battery indicator continues to run at 0% mode, or when adjusting the wh, eg 50% to 30%.
Well, I believe the default value is/was 9Wh. That should be changed to ~15-18. Then (as always) upload to your mod.
I do not understand why you said that. You could use someone elses csv (curve) and values or run your own analysis which will give YOU valid results for YOUR batteries
I want to say: I don't use cvs, but I want to use it like an ordinary mode. When the battery indicator is 0% when using 9 wh, the mode is still working. When using 15-18 wh battery indicator falls from 50% to 30% at a time, or from 40% to 20%.
