Paramike166 Posted February 26, 2019 Report Posted February 26, 2019 Can anyone tell me why my tanks are wiggling even when fully tightened on my paranormal 166. It's only wiggling very slightly and the mod works fine, but I hate the wiggling. What can I do to maybe fix this?
Wayneo Posted February 26, 2019 Report Posted February 26, 2019 If you remove your tank, and look down at the 510 plate, are there a couple tiny torx screws holding it tight? 1
Paramike166 Posted February 26, 2019 Author Report Posted February 26, 2019 Yes there are 3 torks. I must get a work that fits asap and see if that does it. Is this a common problem? Also I thought that maybe the nut holding the 510 plate from underneath could be loose? What do you think??
Wayneo Posted February 26, 2019 Report Posted February 26, 2019 1 hour ago, Paramike166 said: Is this a common problem? Also I thought that maybe the nut holding the 510 plate from underneath could be loose? I've heard of it less than a handful of times for all their products. There is a nut underneath, but unless your resistance was also fluctuating, I doubt it. But easy enough to check when you get the torx. Just lift it straight up and out, less than an inch.
