upon setting up my Orion on the software
where i boost to 0, 1 & 2
warmth at 1
do i always have to open the tank in order to decompress for the juice to flow at the coil?
everytime you would notice when your fire taste its burn out, you just have to open the tank observe that there will be bubble coming out from the coil showing a decompression, only then you will start to taste your juice as nornal once you fire it up again.
so i notice that i alwys to open the tank to avoid firing it up with a burned coil. whether its a 0.25 or 0.5.
anyone?
Edited by D12u
correction
You should get bubbles with the tank closed.... it also may be the juice (PG/VG %) you are using or the wicking inside that tank is too tight....  some people take a paperclip and play with the wicking but I don't know if that really helps....
those bubble will not come out when the tank is closed not too tightly, the juice im using a 50/50 VG/PG
now when i leave the tank open, the juice just overflow on the coil or mouth piece as i fire it up.
tell me how do you use the paper clip on it? on the tank or at the coil portion?
if the coil overflow happens when the tank is open then the wicking is not too tight....  if you take multiple hits in a short time the wicking  maybe can't keep up......
