kalagan Posted January 24, 2019 Report Share Posted January 24, 2019 Hello, I know, I know, it's probably a regular topic but I just can't find the solution despite having a look around. I've got a Paranormal 250C and after changing the coil as usual, I get this message now. The solution seems to clean the coil under it and clean on the connection on the mod but even after doing this I still get that message. I've put the coil on a different mod and I also get this message. Same result when I try another brand new coil. Any suggestion? Thanks so much Link to comment Share on other sites More sharing options...
kalagan Posted January 24, 2019 Author Report Share Posted January 24, 2019 I assumed that the issue was coming from the atomizer (a freemax pro mesh) because it doesn't work on a different mod but actually when I put a tank that works fine on the DNA mod I now get Check Atomizer message ... humm 😭 I've never had so many issues with a mod than this Paranormal Mod .. driving me mad Any advice will be much appreciated! Link to comment Share on other sites More sharing options...
JacobEvolv Posted January 24, 2019 Report Share Posted January 24, 2019 Kalagan, I would take a look at the 510 pin on the Paranormal. Ensure that you can depress the pin and it springs back up. Link to comment Share on other sites More sharing options...
kalagan Posted January 24, 2019 Author Report Share Posted January 24, 2019 Thanks Jacob will check that right away. Did more testing earlier and somehow it works if I put an old prince tank from Smok I never use - but only in TC (ss316/430). If I choose anything else I'll get the usual message. Link to comment Share on other sites More sharing options...
kalagan Posted January 25, 2019 Author Report Share Posted January 25, 2019 (edited) Right so I've checked the pin, if I press on it it does goes down a bit and back up but I’m not sure how smooth that should be. It feels quite stiff but there is some movement possible up and down. Do you mean I should unscrew the screws around it as well to do this? I basically used tweezer to wiggle it and pull it up. Thinking of it, last month if I screwed my tank very tight I would get the Check Atomizer message .. maybe it’s just too low now and won’t spring back up correctly. No idea how to fix that though Edited January 25, 2019 by kalagan Link to comment Share on other sites More sharing options...
