Dodecaphonix Posted November 11, 2018 Report Posted November 11, 2018 (edited) I have two identical Lost Vape Project Sub-Ohm Triade DNA 250C devices. One of them is having charging issues. I've hooked the malfunctioning device up to the Device Monitor and here is what I've observed: it reads a consistent voltage from the usb power supply at about 10 second intervals it will read usb current and then quickly snap back to zero current I've designed a theme where I can monitor these values from the device UI and this behavior is seen on all chargers that I hook it to. Things that I've already attempted in order to resolve the issue: different sets of batteries high amperage USB chargers low amperage USB chargers updating firmware verify that identical, functioning device behaves properly in all above tests Edited November 11, 2018 by Dodecaphonix
James Posted November 12, 2018 Report Posted November 12, 2018 Hmm. If you go into Tools->Serial Terminal, try the command X=READ BMS. That will clear out whatever battery-management errors it may have had in the past. Wait a while and send that same command again. What does it respond with?
Dodecaphonix Posted November 12, 2018 Author Report Posted November 12, 2018 Thanks for the help! Here are my terminal commands and responses. Commands were run 5-10 apart from each other. I've added "in:" "out:" for clarity, but actual terminal commands were X=READ BMS as instructed. What should I try next? in: X=READ BMS out: X=24 in: X=READ BMS out: X=24
