Hi, so I decided to dabble in changing my theme.
I use Frank65's blue theme in my 3 DNA color devices and what I want most is to put the puff counter in the bottom left corner.
This field is blank in wattage profile, but shows 'last watts' in temp profile.
In theme designer when I changed the field from 'last wattage' to 'information total puffs' I saw there was no change to the mod.
Then I toggled to a temp mode and saw my beloved puff counter where I had changed it.
So this is where I am stuck.  I am just trying to get the puff counter on the main screen, thanks!.  Link below to the theme:
I just had a look at the theme, there's a condition that hides last temp on a non temp sensing coil, you'll need to delete the condition.  There's a voltage display in non-temp mode also in that theme, I guess you'll want to delete that if you haven't already.
