Nightmaerz Posted October 16, 2018 Report Posted October 16, 2018 guys, Trying with TC mode, i adjusted all the settings and uploaded material wich i found here. But when i use device monitor the resistance starts lower then the cold resistance...? so it starts measuring at -50 degrees. how can i help this? thnx in advance
Wayneo Posted October 16, 2018 Report Posted October 16, 2018 4 hours ago, Nightmaerz said: i adjusted all the settings and uploaded material wich i found here What type of material are you using AND post the link for the material file
Nightmaerz Posted October 16, 2018 Author Report Posted October 16, 2018 used ss316l using djaquith v3.5 https://drive.google.com/file/d/0BwvlbDzrOqwFVWI0Qk1GQmJpRDg/view?usp=sharing
Nightmaerz Posted October 16, 2018 Author Report Posted October 16, 2018 this is my profile. internal resistance set to 0.014 profilexample.ecigprofile
Wayneo Posted October 17, 2018 Report Posted October 17, 2018 All I can think is that perhaps the coil was not at ambient temp when you went into temp control. Maybe take the atty off your mod, hit the fire button so the mod shows check atomizer, let the atty sit for a bit (say half hour), reinstall atty answer 'yes' for a new coil if prompted. Ideally it'll show a resistance lower than before. If that doesn't work, What kind of atty, and can you describe the coil
