Droopydroors Posted October 15, 2018 Report Share Posted October 15, 2018 I have 2 Orions and i switched a pod from one to the other and noticed a very different hit between the two. They are both using default settings and on the red light without replay set. So i hooked the one up to escribe to check device monitor and sure enough no matter what wattage i put in it stays at 8 watts. I put it up to 15 watts and it only goes to 8. It seems as though it may be stuck in a replay. So far i have tried restoring to default settings but nothing changes. Any ideas? Link to comment Share on other sites More sharing options...
Droopydroors Posted October 15, 2018 Author Report Share Posted October 15, 2018 So I found a work around if anyone else has this issue. This was happening with a .5ohm pod so I went in to the "Mod" tab and un checked the "Enable" box above the MTL settings. Then I set the DL Max resistance to 0.695. So basically both pods will run the same wattage. I have the White set to 11 watts that I will use for the .5ohm pods and for the .25ohm pods I will use the Blue and Red settings set to 13 and 15 watts. I guess that's the great thing about escribe, even though my device is faulty I can still use it! Link to comment Share on other sites More sharing options...
