Hi all. I have a problem with my Finder 250C.  If i re read ohms it jumps too much from 0,35 to 0,38. In temp control i’ve getting temp control with power cut off. Is there something wrong with my mod ? In Replay mode is check atomizer error after few puffs. My atty is berserker mtl rta with 0,35 ohms simple coil.
Update: in temp control i’ve getting temp protect message
Update: i using ss316l simple coil build. I tried resolder ground wire because i read there on forum it can be grounding problem and nothing help
Have you tried other atty's? Or is it happening with Berserker MTL RTA only? I've had similar issue with my Berserker MTL RDA sitting on top of Asmodus Pumper 21 - mod would simply be cussing at me.
I have also had similar issues with mine. Very erratic with resistance, room temp going from 60-100.  Many tanks the same which fine on other DNA mods.  Turn on replay when I get it stable and it is like I increased temp by 100 degrees. I am in the process of sending it in for repair.
