MFB Posted July 30, 2018 Report Posted July 30, 2018 (edited) I charge the batteries by 100%, 4.1V ~I put in my mod, shows a 100% charge, after a few minutes the charge drops to ~ 30% and the board writes an imbalanced battery. Esribe reacts the same way. Shows voltage 4.1 on one battery and 3.2 ~ on the second. What is the problem and how to solve it? UPD:When the board writes imbalanced battery mods continue to work, soaring can continue Edited July 30, 2018 by MFB UPD
retird Posted July 30, 2018 Report Posted July 30, 2018 Do you get the same results using a different set of batteries??? Did you check the voltage of each battery with a volt meter?
