Arthur-EV Posted May 31, 2018 Report Posted May 31, 2018 (edited) Hi there, I searched the forum previously for info on this, but only found one thread suggesting the screen size, and I am not sure if that info is correct. Also, I had sent a message to Evolv support 2 days ago and have not received any reply as of yet, so I figured I'd try the forum here to see if anyone has an authoritative answer. I've also tried to find a way to contact SXK and either their web site is hard to find or my google-fu is broken. So I am hoping that someone on this forum can help me with the correct info. I've managed to accidentally tear the mylar ribbon wire completely off of the edge of the display screen on my DNA60 that is inside my SXK Billet Box clone. I would like to order a replacement screen, but I am not sure if I need the LARGE or the SMALL screen for the DNA60 that will fit as an exact replacement for the SXK DNA60 Billet Box clone.. The ribbon cable attaches to the board with that tiny flip-lock connector, IIRC sometimes referred to as a ZIF connector. Please advise which screen I need to buy as a replacement. Also, does the screen come with that small, black adhesive foam pad like how it is mounted originally? If not, do you know where I can source one, or what I should use in it's place? Thank you for your time and consideration. Arthur Edited May 31, 2018 by Arthur-EV typos
Wayneo Posted May 31, 2018 Report Posted May 31, 2018 1 hour ago, Arthur-EV said: but I am not sure if I need the LARGE or the SMALL screen for the DNA60 that will fit as an exact replacement for the SXK DNA60 Billet Box clone Apart from the larger wattage or temp field on the right side of the screen, HOW MANY little fields were shown down the left hand side? 2 is a small screen, 3 is a large screen. And screens do not come with double edge tape, at least not as part of a full board and screen purchase.
Arthur-EV Posted May 31, 2018 Author Report Posted May 31, 2018 (edited) 7 minutes ago, Wayneo said: Apart from the larger wattage or temp field on the right side of the screen, HOW MANY little fields were shown down the left hand side? 2 is a small screen, 3 is a large screen. And screens do not come with double edge tape, at least not as part of a full board and screen purchase. Thanks for the reply. This is a photo from FastTech showing the screen on mine: https://img.fasttechcdn.com/835/8356301/8356301-8.jpg Taken from: https://www.fasttech.com/products/3024/10011697/8356301 So does that mean this is the LARGE screen then? Edited May 31, 2018 by Arthur-EV
ruudde Posted June 1, 2018 Report Posted June 1, 2018 I own the same BB and I'm sure it's the large screen
Dre11 Posted June 5, 2018 Report Posted June 5, 2018 Does anyone know which exact board is used in the SXK clone ?
