Haitham Ramadan Posted May 27, 2018 Report Posted May 27, 2018 Good day, I am a coil builder & i am starting to get questions from my customer about best coil core to be handled with replay mode, so any suggestions about best compilation of cores & outers wires that get the best out of replay?
Haitham Ramadan Posted May 29, 2018 Author Report Posted May 29, 2018 Ok here what i found out till now, so even with KP profile didn't detect replay, i have build today a triple core SS 26G with 36 N80 & its functioned brilliant & flavor OMG from another world on ammit 22 that i own for year & half now & thats the first time to taste my own juice like this :), still gonna try n80 as core & SS as outter & i'll update u
VapingBad Posted May 30, 2018 Report Posted May 30, 2018 Using all SS316 would probably be best, any temp sensing wire, but not mixing metals will give you the best results.
Bajifista Posted May 31, 2018 Report Posted May 31, 2018 I'm having problem using the superfine mtl ss316 wire by vandy vape, it should work but the replay square is blank, any ideas?
Haitham Ramadan Posted June 1, 2018 Author Report Posted June 1, 2018 On 5/31/2018 at 6:27 PM, Bajifista said: I'm having problem using the superfine mtl ss316 wire by vandy vape, it should work but the replay square is blank, any ideas? Did u made sure u activated the replay by clicking check box in escribe as the same profile u running on ss316, by the way don't try it in TC profile, it will not work, it should work in wattage prfile
Haitham Ramadan Posted June 1, 2018 Author Report Posted June 1, 2018 On 5/30/2018 at 8:33 PM, VapingBad said: Using all SS316 would probably be best, any temp sensing wire, but not mixing metals will give you the best results. theoretically yes, but believe it or not the SS with N80 giving a more condensed flavor & warmer vape on same wattage, give it a shot
MrToast Posted June 3, 2018 Report Posted June 3, 2018 I'm a newbie to DNA mods, I'm using a simple ss hamd made coil and replay is working fine for me, one question I do have is under atomiser replay is set to a value of 5, what difference does changing that value make?
Haitham Ramadan Posted June 4, 2018 Author Report Posted June 4, 2018 14 hours ago, MrToast said: I'm a newbie to DNA mods, I'm using a simple ss hamd made coil and replay is working fine for me, one question I do have is under atomiser replay is set to a value of 5, what difference does changing that value make? If u leave it as it is that the auto adjustment from replay mode, if u choose to change it it will affect it by raising up the start watt to make coil more hot & so for lower is will start at lower wattage, u can say it a punch or boost but for replay option
