truckman Posted May 27, 2018 Report Posted May 27, 2018 (edited) Is it possible to set maximum power for boost (e.x the 100watts ) via mod with 75c board without the use of escribe? I do not find any appropriate command in theme manager for that. Edited May 27, 2018 by truckman Edit
niandra3 Posted May 28, 2018 Report Posted May 28, 2018 I don't think so. I'm pretty sure the way it stands now you need the International EScribe Version, and in there you can set the boost and raise the wattage max. Not sure if you need latest 75c firmware or not (usually worth it to upgrade that too)
engmia Posted June 9, 2018 Report Posted June 9, 2018 On 5/27/2018 at 11:05 AM, truckman said: Is it possible to set maximum power for boost (e.x the 100watts ) via mod with 75c board without the use of escribe? I do not find any appropriate command in theme manager for that. Expand It depends on the theme your manufacturer built. It was possible on my Lost Vape Mirage 75C
truckman Posted June 9, 2018 Author Report Posted June 9, 2018 I have seen that this setting is only possible to preheat (tc mode), but not in boost( wattage mode). Are you sure about this? Do you have a link to the theme you are using and can you do that?
