Not sure if I would call this a bug, however I have noticed that all the temp fields (last puff temp, last puff peak temp, recordings temp etc.) return null if temp protection is disabled.
You can still see the temp ramp up either on the device graph or using device monitor, meaning the board is still actively monitoring... so why disable these fields ?
I don't want to use temp protection, although still want temp to be reported back on my screen.. I would rather replay take care of the temp control instead of setting a hard limit.
I would really appreciate if these fields were active all the time regardless if temp protection was enabled while using temp sensing wire..
Edited by ruckus
6 hours ago, iambyrdman said:
Good question.  I've wondered why Temperature doesn't get reported.  Might be why, now I just need to find the setting...
You can toggle temp protection by toggling "temperature" on escribe under profiles.
Edited by ruckus
