Nick Posted April 19, 2018 Report Posted April 19, 2018 Coil: 0.2ohm Material: Unknown Replay Compatible: No Coil: 0.4ohm Material: Unknown Replay Compatible: Dubious The 0.4ohm coil seemed to work fairly reliably. I do not believe it to be a material with a well defined TCR however due to the construction of the coil it locks in easily and vapes well.
mactavish Posted April 19, 2018 Report Posted April 19, 2018 Are you sure there is an atomizer called “OBS Damo”, couldn’t find it to online. I’m thinking you meant OBS NANO, I own two of those, which work fine in TC, but until the firmware for DNA75c’s is released, I can’t check it for REPLAY.
Nick Posted April 19, 2018 Author Report Posted April 19, 2018 14 minutes ago, mactavish said: Are you sure there is an atomizer called “OBS Damo”, couldn’t find it to online. I’m thinking you meant OBS NANO, I own two of those, which work fine in TC, but until the firmware for DNA75c’s is released, I can’t check it for REPLAY. https://www.vapordna.com/OBS-Damo-Sub-Ohm-Tank-p/obsdam.htm
mactavish Posted April 19, 2018 Report Posted April 19, 2018 Google failed me, good catch. I will say you should consider adding the full name, OBS DAMO SUB-OHM TANK, these days sub-ohm means prebuilt coils, as opposed to RTA, up to you. Good work!
Nick Posted April 19, 2018 Author Report Posted April 19, 2018 On 4/19/2018 at 4:25 PM, mactavish said: Google failed me, good catch. I will say you should consider adding the full name, OBS DAMO SUB-OHM TANK, these days sub-ohm means prebuilt coils, as opposed to RTA, up to you. Good work! Thanks! I don't think rebuildables are worth having in here as the user has near infinite choices of what they want to use. If using Replay is desired then a Replay compatible material should be used. A build that works on one rebuildable should work fine on any rebuildable as long as there is not a connection issue at play. We can certainly have a thread to discuss good builds for Replay though. I do understand that certain builds may be good from a coil fitment and flavor standpoint on one rebuildable, but not another. We'll talk this over internally and find a way to accommodate users that want to share information about a specific rebuildable atomizer as well.
mactavish Posted April 19, 2018 Report Posted April 19, 2018 Oh, I didn’t realize this new thread was about sub-ohm tanks that take pre-built coils, my mistake. That of course opens up a world of other issues as I’m sure you know, as many of these tanks have multiple options for their coils, some not being TC compatible to begin with. To be truly useful, folks that post here should be very specific as to what pre-made coils they are using.
