KMac Posted April 15, 2018 Report Share Posted April 15, 2018 Well a few are showing theirs off so here is mine. 4 Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 24, 2018 Report Share Posted April 24, 2018 Have you had any initial battery problems after getting all together? Link to comment Share on other sites More sharing options...
KMac Posted April 24, 2018 Author Report Share Posted April 24, 2018 None I did the all the calibrations ie the battery analyzer and case analyzer. Replay doesn't seem to like my Steam Crave Titan no matter what build I use but using a Kylin it's working flawless. Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 24, 2018 Report Share Posted April 24, 2018 I see.. Which battery are you using in your build? Link to comment Share on other sites More sharing options...
awsum140 Posted April 24, 2018 Report Share Posted April 24, 2018 (edited) I just built an N1, too. What size battery did you use? Mine is a 2200mah, 4S, NanoTech. Edited April 24, 2018 by awsum140 Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 25, 2018 Report Share Posted April 25, 2018 31 minutes ago, KMac said: None I did the all the calibrations ie the battery analyzer and case analyzer. Replay doesn't seem to like my Steam Crave Titan no matter what build I use but using a Kylin it's working flawless. I can't do any of the calibrations, since the battery won't charge.... Link to comment Share on other sites More sharing options...
KMac Posted April 25, 2018 Author Report Share Posted April 25, 2018 Are you using a 3S or a 4S? I've used a 3S for a week or so while waiting on the 4S to arrive just need to switch the config in Escribe but no issues at all for me. Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 25, 2018 Report Share Posted April 25, 2018 I"m using a 3s, I switched the config in the Escribe, and I see voltage coming from the USB, but not charging the battery. Link to comment Share on other sites More sharing options...
KMac Posted April 25, 2018 Author Report Share Posted April 25, 2018 on the board did you jumper the the last connector pin 4 either back to 3 or to B+? do you see each cell voltage in device monitor? when I was ruining it in 3S I just jumped it to the B+ Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 25, 2018 Report Share Posted April 25, 2018 Hm, I didn't run a jumper wire to the fourth pin, I didn't think I needed to worry about the fourth pin... I suppose that's what I get for not checking a wiring diagram. Now, I'll have to try and undo the JB weld I used to hold in the chip holder... Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 25, 2018 Report Share Posted April 25, 2018 Well, I pulled it apart, and soldered a jumper wire from 4 to B+, but it's still not charging through the USB. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted April 25, 2018 Report Share Posted April 25, 2018 @Ryan Brooks Can you post a screenshot of Device Monitor with all of the battey options boxes ticked? An you are positive you have "3-cell" selected in EScribe and uploaded to the device? I would re-go over your battery wiring/soldering to the board, as well; balance tap connections and all. Link to comment Share on other sites More sharing options...
Ryan Brooks Posted April 25, 2018 Report Share Posted April 25, 2018 I'd post pictures, but I got irritated and pulled it all apart and resoldered it, but I did have everything soldered up correctly. Link to comment Share on other sites More sharing options...
