Grounding DNA250 Hana MODZ DIY
zombo
You could use the 3 mounting screws that hold the board in the enclosure as they are ground. Make sure that your 510 is tightly screwed into the enclosure as that will be the ground for the 510.  OR you can run a ground wire from the power out ground solder pad to the shell (silver part) of the 510.  Here is a data sheet that also has a wiring schematic and picture...
https://downloads.evolvapor.com/dna250.pdf
