vern Posted January 24, 2018 Report Posted January 24, 2018 i have a perfect 250 board that was previously set up as a 167. i need any 250 file available. ive looked over the forum and dont see one. can someone point me in the right direction?
Wayneo Posted January 24, 2018 Report Posted January 24, 2018 For a completely clean file, on the front page when you start escribe it's right there as 'Evolv dna 250'.
Wayneo Posted January 25, 2018 Report Posted January 25, 2018 (edited) Those are all the standard Evolv defaults, and any 3 battery mod will work fine using them straight out of the box. Battery - You can create or load your own battery curve which only affects the gauge display in combination with Watt hours input. Cell soft cutoff for message when you're hitting that 'lower' limit. Case thermals - Mainly for TC usage, but also useful for when your batteries are getting old and heating up. Mod resistance - Mainly for the most accurate coil resistance readings, especially for TC usage. Edited January 25, 2018 by Wayneo And welcome
